Results 1 to 10 of 23
Thread: Ventilation
    Mt Cotton
    Hi guys as some of you would know I fit sunroofs for a crust we encounter cross roof braces constantly . The T4 is a sweet model to fit a sunroof into as the rear sections have the cross brace only at the high points cutting between these will not affect the strength . My old dearly departed T4 had a fully built in sunroof at the front section and I removed the cross brace for that one but the sunroof and its supports more than made up for its loss . I then fitted an electric external sliding roof into one of the back sections easy as pie to do no brace to remove even fitted a remote switch up at the dash so I could open it with out any one in the back doing it .
    Mar 2012
    West Ryde, NSW
    When you do cut the hole, DO NOT use and angle grinder.
    A friend did this on her van and she had to get the whole van professionally polished to remove all the metal splinters that etched into the paint work whilst hot and then started rusting causing a major issue.
    she was advised the best method is a metal nibbler.
    Good luck
    Mt Cotton
    We use a Bosch electric shear it slices the steel no filings no clippings it is two hardened steel blades one fixed one tilted the tilted one moves at very fast stroke and only moves a couple of mls so the steel is sliced so to speak the finished edge is so smooth you could not cut your self on it plus it does not distort the finished edge . We still hear of DIY people who have either grinded jigsawed or used nibblers these went out with the dinosaurs in our book . Nibblers are only marginally better than jig saw as they spit out hundreds of what we call robots fingernails . The shear does not cause any filings at all .
    Feb 2009
    Torquay
    I was always keen to put one of these in the roof:
    Jaycar Electronics: Solar Powered Ventilator
    or Solar Powered Ventilator - Jaycar Electronics
    They're solar, battery back up (48hrs), reversible air flow.
    Have not been brave to cut hole in new(ish) T5 (good advice about the angle grinder)
    Mt Cotton
    Just remember if doing a T5 it has a ribbed roof from just behind the drivers door all the way back makes it a real bitch to fit any thing into , when I did fit a sunroof into mine it took six hours to profile cut the frame of the sunroof to fit the ribs then I had to fit packing pieces under each of the ribs on the out side .
    Aug 2012
    Qld
    Thanks for all the great tips and info. By the time I decide on which type of vent/hatch to install I’ll hopefully have enough courage to take the plunge! At the moment I’m tending towards one around the 350 x 350 mark mainly because I got the ladder out today and noticed that it looks like you can’t go much bigger than this without taking in the curve of the roof. As I worry about possible leaks, keeping it as flat as possible might help.
    Aug 2012
    Qld
    Hi, do you usually mark and cut from the inside or the outside of the roof? Thanks
    Mt Cotton
    sorry about late reply always cut from outside we also use masking tape to stop any marks on paint work , we use an air chisel to cut a triangular hole first so we can then use the Shear both operations leave no filings
    Aug 2012
    Qld
    Thanks for all your advice Sunny. So does that mean that you can put your weight onto the ribbed sections to do this?
