Results 1 to 10 of 16
Thread: tyre load ratings
    Aug 2011
    brisbane
    tyre load ratings
    can someone tell me what the minimum load rating is for a LWB with 17" rims. the sticker says 103 for one size, 102/104 for another size. would this be the minimum? also, can the fronts get away with a lower rating?
    my son got defected for having too low a rating, and someone told him he only needs to up-rate the rears. i don't agree?[IMG][/IMG]
    Jun 2011
    Sydney NSW
    The load ratings are minimum, so you can go up. The same for speed ratings as well.
    Actually it's a wonder how many vehicles are out there with the wrong tyres.
    IN2VWS Guest
    Shop around, the correct rated tyres are not that expensive.
    Aug 2011
    brisbane
    he's got 215/55/17 95 stretched on now, but can't seem to find these with the correct load rating. anything larger will catch on the guards. cops threaten to impound the car if it's seen on the road without the correct tires. ride height and rim width was not a problem!
    Jan 2009
    Quote Originally Posted by ericcs View Post
    European vehicle manufacturers usually don't state a 'minimum' load index. Rather, the load index must match the specifications for each tyre fitment.
    This explains why you can fit, with the manufacturer's approval, a 215/65 R17C 104/102T commercial tyre (load index = 104, single fitment) and a 235/55 R17 103W XL passenger tyre (load index = 103) on the same vehicle.
    Australian regulations are more relaxed, in that they allow you to fit any tyre provided it does not have a lesser load index than the smallest load index stated on the tyre placard.
    Not unless explicitly permitted by the vehicle manufacturer.
    Please double check.
    A 205/55 R17 tyre has a load index of 91 (standard load) or 95 (extra load).
    A 215/55 R17 tyre has a load index of 94 (standard load) or 98 (extra load).
    A 215/50 R17 tyre has a load index of 91 (standard load) or 95 (extra load).
    In any case, the tyre is woefully insufficient and overloaded in terms of load capacity, considering the OE fitment is 235/55 R17 103W XL (!)
    Can you upload a photo of the placard or type it up?
    Mt Cotton
    Ours is a SWB but we run Federal Formosa 235/55 RZ17 103 W XL according to the Keith4Wheels they are correct give him a call they are at Springwood . According to the tyre placard these are correct for my 2.0 litre petrol van based on 17 inch rims our other T5 2.5 turbo diesel has the same ones listed as acceptable with only one tiny difference the placard shows 103 Y/W XL so I think they have two types listed for the Turbo model again SWB
    Aug 2011
    brisbane
    the rims are 17x8 and he can only get 215's under the guards, hence using passenger rated tires. he was warned before he altered the offset. it's turned around now and bitten him on the bum as he's got a $110 defect fine and needs tires which he will struggle to get
    for diesel_vert
    [IMG][/IMG]
    Jan 2009
    Thanks for the photo, that clarifies things. So according to the placard, local regulations means that any tyre fitted should have a load index of no less than 103.
    If you look around, there should be another placard (upload another photo if you can) listing the:
    Maximum front axle load (1)
    Maximum rear axle load (2)
    Gross vehicle mass
    Gross combination mass
    So even if you choose to fit tyres with a lesser load index than stated on your tyre placard (103), you should at the very least ensure the tyre can support the max. front & rear axle loads, for safety's sake.
    Sorry to hear about the fine, but isn't it incredibly worrying driving around on tyres with such an insufficient load capacity?
    Aug 2011
    brisbane
    Quote Originally Posted by Diesel_vert View Post
    Gross vehicle mass
    i understand the implications of using underrated tires, and told him so. the only comforting fact was, he only used it to cart his dirt bike around. the suspension itself wouldn't allow a big load
    I'll look for the other placard tomorrow
    Jan 2009
    Well, we were all young once.
    It's fortunate that $110 is all he lost.
