on kw k3 coilovers about 80mm drop
[IMG][/IMG]
[IMG][/IMG]
I lined it up so the i in my tdi badge is where the pipe touches so it doesn't rub the paint work. It pushes the pipe up about 15-20mm when the tailgate is up even when loaded with copper tube it moves it easily. My ladder also is very close but also has a 15-20mm gap from the end of the ladder to the glass
[IMG][/IMG]
[IMG][/IMG]
Maybe not as intentional as some of the photography in here...
Seems maybe I found a soft spot
4WD + tow rope = problem solved
Traction control on or off we were in a similar situation some years ago and ours crawled its way out by itself , had foot flat to floor but the TCS dropped the revs and it alternated grip from one side to the other front wheels only and we escaped even with fully loaded trailer with MX bikes on board .
Will post some pics of my T5 once I have built up enough credibility with this forum to allow me to post pics...cheers Dean
Fits even with the bench in!
My T5 Just Cos I can.
What suspension kit did you use please .
It's an h and r coil over kit. Tried a cheapo set before but they were noisy and bouncey .
wheels are 20" commodore wheels off gumtree with hub centric rings and standard bolts.
2013 Tour of Duty to Victoria
