I posted on this some time ago mentioning I didn't feel confident pulling the latch/lock unit out. This is information only in case anyone else wants to.
- Central locking had failed, including window wind-up and rear door lock (no manual keyhole)
- Central unlocking worked fine
- Dash warning indicator stayed on (cause for failing safety check in this state/country)
In photo attached
- Thick wires I assume carried solenoid current
- Thin wires are sensor signals tied to 12V at the logic unit end via resistor. ie the line is taken to ground at the microswitches.
- Yellow/blue was normally at 12V (10-14V) unless the manual key was turned fully one way or the other when it dropped to 0V. No doubt the central locking/unlocking when using the key rather than the remote.
- Green yellow was at 0V till I cut it and to be honest I couldn't reason its actual function. With it cut all the door locks gave a thump (unlock?) when the ignition was turned on. I had a jumper on it this photo till resoldering.
- Black was at 0V till I cut it. It now thinks the door is always shut. That can cause some odd behaviour, like it relocks when I get back into the van without starting etc.
I hope someone will find this useful.
The green wire connects directly and only to the control module.
