Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Trans Cooler for 6 speed auto
    Aug 2008
    I had a new filter and 4 lts of Penrite SIN ATF added to the box last week. Oil that came out was black and the magnets in the bottom of the sump were covered in fine metal particles.
    I plan on doing it once a year. Hopefully it helps.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Feb 2008
    Adelaide,Oz
    I don't think running the engine to pump all oil out is a good idea.$$$
    I used Penrite DX-VI in '08 as it was recommended by Penrite tech at the time.
    how to change T5 Auto Gearbox Oil - The Brick-yard
    I noticed the new T5's auto boxes are rated for 600Nm
    Steve
    04 T5
    Adelaide hills, SA
    Quote Originally Posted by Rebuild View Post
    That's what Mitsubishi factory workshop manual says when changing ATF in V6 Magna.
    Sent from my HTC Desire using Tapatalk
    Feb 2008
    Adelaide,Oz
    so, you are saying we could run the box to drain all the fluid ??
    Steve
    04 T5
    Adelaide hills, SA
    No, here is how is done on Mitsubishi V6 Magna
    I'm sure that VW factory manual says just drain and refill.
    Just make sure you seal the filling plug well and always use a new O-ring.
