I had a new filter and 4 lts of Penrite SIN ATF added to the box last week. Oil that came out was black and the magnets in the bottom of the sump were covered in fine metal particles.
I plan on doing it once a year. Hopefully it helps.
Printable View
I don't think running the engine to pump all oil out is a good idea.$$$
I used Penrite DX-VI in '08 as it was recommended by Penrite tech at the time.
how to change T5 Auto Gearbox Oil - The Brick-yard
I noticed the new T5's auto boxes are rated for 600Nm
so, you are saying we could run the box to drain all the fluid ??
No, here is how is done on Mitsubishi V6 Magna
http://lh6.ggpht.com/_std7SMZaoXg/TI...ge%20Mitsi.JPG
I'm sure that VW factory manual says just drain and refill.
Just make sure you seal the filling plug well and always use a new O-ring.
Sent from my HTC Desire using Tapatalk
