Results 1 to 9 of 9
Thread: Are Touareg wheels safe on a Transporter?
    Nov 2012
    Hey all,
    I've been looking around for some second hand genuine VW wheels for my T5 transporter and have come across some nice 17" alloys off a 2011-2012 touareg.
    My local VW dealer claims there is no way to really tell if they are load rated or not, but most likely are. Obviously I need to confirm if they are or not as its a serious safety issue if not.
    I have images of the stamps on the back of the wheels.
    Can anyone shed some light on this issue for me please?
    Thanks all!
    Dec 2005
    Rockhampton Qld AU
    PCD is wrong. R5 touareg is same as T5 which is 5 x 120. Other touaregs are same as Porsche, which is 5 x 130.
    '11 Polo TDi auto, White, Sunroof
    '91 Transporter syncro camper
    Nov 2012
    Thanks for the response njg02. Sorry but I don't understand PCD. The seller tells me the wheel stud offset is 5x120 which I understood as matching my T5. Is this not correct?
    Adelaide hills, SA
    You will find more about the wheels in this thread T5 FAQ and How to THREAD (up to August 2009).
    Nov 2012
    Thanks transporter.
    Your link confirms that transporter wheels are PCD 5x120 as are the touareg wheels I'm looking at.
    Is there any information about the load rating of such wheels that you have seen?
    Thanks!
    Adelaide hills, SA
    Re: Are Touareg wheels safe on a Transporter?
    On Touareg2, it's casted on the wheel, visible only when the wheel is off. If the wheel you looking at is the OEM on R5 Touareg, then they should be safe to use on the T5.
    Sent from my GT-N8000
    Jan 2009
    Quote Originally Posted by JoeT5 View Post
    Hey all,
    Thanks all!
    I think the wheels on the new Touareg (7P5) have a pitch circle diameter (PCD) of 130 mm.
    As others have pointed out, the wheels for a Transporter have a PCD of 120 mm.
    What are the part numbers (should be 9 to 11 characters long) for the wheels you currently have, and the wheels you are intending to buy?
    Adelaide hills, SA
    I'm sure the R5 Touareg (Touareg) are the same as on T5. The Touareg2 won't fit.
    Jan 2009
    Yeah, that's what I'm thinking.
    OP mentions wheels off a "2011-2012 Touareg" - which is the new model.
    Anyway, the part numbers should tell all.
