Results 1 to 7 of 7
Thread: torque setting
    Mar 2015
    hallam vic
    torque setting
    Hi guys.
    I am about to fit a new DMF and clutch on my t5 2.5 tdi 2005 model.
    Does anyone knows what is torque setting for the flywheel and pressure plate bolts.
    someone told me it is 22nm + quarter and 18nm + quarter for pressure plate. Is this enough tension for this important part???
    Erskineville, NSW
    Quote Originally Posted by kolina View Post
    Hi guys.
    It doesn't sound right.
    On a Golf the flywheel to driveplate torque is 60Nm + 1/4 turn (single use stretch bolts).
    I don't think the pressure plate to flywheel bolt is a stretch bolt. On a GTI M6=13Nm & M7=20Nm
    /searches - appears to be:
    60Nm + 1/4 turn using new stretch bolts for the flywheel.
    22Nm for the pressure plate
    Mt Cotton
    Just a quick one what did the new DMF cost and then the clutch , sometime soon I will need to do mine . I suppose after 290000 kays it should be done after all reversing has become a real act of clutch feathering and slipping to get a smooth reverse movement . I did replace the clutch assembly at 180000 but did not know about DMF at the time even though it was shuddering in reverse I just thought it was like the good old ones where the springs were around the clutch plate itself and not buried inside the flywheel .
    Mar 2015
    hallam vic
    Hey Brad ,Are these torque values you gave me from the manual. ?
    Can I go ahead and finish the job/
    Mar 2015
    hallam vic
    I have paid $1.188 for the clutch kit and DMF from the place in Dandenong Vic
    Feb 2008
    Adelaide,Oz
    for an 05 T5 0A5 6spd manual
    22Nm for pressure plate bolts, tighten diagonally in steps
    60Nm for flywheel, plus 1/4 turn
    Steve
    04 T5
    Mar 2015
    hallam vic
    Thanks Steve.
