Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: The Torque Converter Auto (NOT DSG) T5 thumps into drive when cold
  1. #31
    Dec 2008
    Sydney/Canberra
    100% the parts and oils were available. I was doing them as early as 2008.
    The main reason the dealers never pushed the issue was that nobody wanted to pay for it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #32
    Adelaide hills, SA
    Quote Originally Posted by Umai Naa!! View Post
    I had exactly the same reply from VW spare parts “we can order it for you, but it’s very expensive”.
  3. #33
    Mt Cotton
    I was told the gasket was around $15 and the filter $45 plus the filler unit and fluid .
  4. #34
    Feb 2008
    Adelaide,Oz
    Had a brief in person chat with David from Automatics of Marion, today.He actually had a T5 up on the hoist, and gearbox in bits when i was there.Showed me a few of their probs.
    With mine, he did mention something about o-rings going hard, which may explain the rubber like particles i found, or some prob with forward clutch where a thrust washer or similar spins, digging into metal.He did say it was hard to diagnose without going into the box.
    He explained that he was a bit full up these next few weeks, so may see him again in October, for a full dismantle and inspection/rebuild.
    Will cost a few dollars, in the region $2K or so, can't be exact at the moment.
    My solenoid resistance measurements were in the ballpark
    Steve
    04 T5
  5. #35
    Jun 2007
    Melb.
    Fair enough however were you doing them as per a factory service scheduled item. I'd be surprised if that's a yes because my own service manual never listed a transmission service of any kind and it was only when problems started showing up that word started spreading. T5 I think hit the road in Europe in 2004 so euro vans by 80K were starting to show problems...and the auto wasn't the major seller as well.
  6. #36
    Adelaide hills, SA
    Yes, the amount of auto transmissions in the van (and cars too) in Europe is insignificant, plus they generally don't last as long as ours, because of the winter conditions.
    The owners manual in the glovebox and its servicing section is a guide only and most likely it has written something like "for an uptodate servicing information see the dealer".
  7. #37
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Tornado T5 View Post
    It wasn't part of the service schedule until around 2010-2011. But subsequently removed due to the aforementioned costs involved.
    Even if it wasn't part of the schedule, there was no reason why a customer couldn't have it done, if they were happy to pay for it.
    '01 Beetle 2.0
  8. #38
    Jun 2007
    Melb.
    The issue is by not having it listed initially most owners were never asked to have the service and for those with some knowledge how many thought to ask for it as well?
    One could argue that removing it and then have failures occur outside of warranty might be a "another" reason for removing the schedule as well.
    Sadly I wouldn't consider this an unlikely scenario based on the historical behavior of VW.
    Didn't the T5GP with change to dsg version come out at this time also?
    Ironically I paid the high charge for the service and sadly right afterwards had the transmission fail and replaced, lol. One could say I caused the disturbance of the up until then perfectly functioning auto and a clean out didn't increase longevity.
  9. #39
    Feb 2008
    Adelaide,Oz
    Gearbox is fixed thanks to Dave at Automatics of Marion.
    K1 clutch clearances over spec and seals damaged, causing the thumping.
    Anyway, all fixed.Dave did his various modifications that he does for these, and some other stuff(K1 piston and friction fibres replaced, new more reliable small can solenoids, air cooler). Refilled with my choice of Penrite ATF FS. All up $3500ish.
    Steve
    04 T5
  10. #40
    Feb 2008
    Adelaide,Oz
    163K
    Around Easter i noticed a new problem with the gearbox, flaring on the 5 to 6 change, all the time. Plus an intermittent flare on the 2 to 3.
    Talked to Dave again, and he suspected a bad solenoid, as did I.
    Got it back to him so he could roadtest and check it out.
    As a first resort, he replaced a few solenoids, which didn't end up fixing it.Then he tried a recon valve body, better but not fully fixed.This was all free of charge, which was very good of him.
    Last option was to remove the box again.Ended up replacing the B1 piston,seals,fibres and steels, which seems to have done the job.
    Steve
    04 T5
