Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 68
Thread: Tires.....What to get?
    Adelaide hills, SA
    Quote Originally Posted by Rebuild View Post
    got Hankook Dynapro HP's on mine ATM.Grips ok.Only done about 10K so far,but the fronts are looking a little more worn than I'd like.Will see how they last.
    Do you rotate your tyres evey 5,000km?
    Also I pump them up to 50psi pressure.
    Mar 2008
    On my T4 Caravelle I purchased the OEM Goodyear Cargo load rated tyres. About $200 each fitted.
    The new Multivan came with Dunlops as the OEM tyre.
    Regards,
    Scott
    Feb 2008
    Adelaide,Oz
    Quote Originally Posted by MRL T5 View Post
    not rotated yet, but will do soon.Run 45psi
    Steve
    04 T5
    Jan 2007
    Latest price on the DynaPro HP's is $235 each. Was offered Michelins and Yokohamas for $500+ each. I can't justify that. Have just ordered four of the DynaPro.
    Cheers,
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    Adelaide hills, SA
    Quote Originally Posted by shogun2 View Post
    Cheers,
    Was it DynaPro RA23?
    I was told on Monday at Bob Jane that DynaPro HP was not available. RA23 replaces DynaPro HP. I check the RA23 tread pattern and it looks almost identical to HP. I didn't check for differences in construction between the two.
    Still less expensive than others.
    Jan 2007
    It's probably the RA23. This was the model suggested to me when discussing the DynaPro. I didn't realise the RA23's were a newer model. It appears they have a very similar construction and tread.
    Hond Civic VTI 2001
    Jan 2007
    Tyres on the T5 tonight - DynaPro HP, not RA23.
    Hond Civic VTI 2001
    Jul 2005
    I met a man from Shepparton who had a T4 Transporter that was fitted with extra seats.
    He had Goodyear Cargos fitted and he says he got about 120,000kms from the first set, and would do at least the same on the second set.
    Maris
    Adelaide hills, SA
    Quote Originally Posted by WEDEL.1 View Post
    Maris
    It is hard to believe but anything is possible.
    He had probably regularly rotated his tyres and checked the tyre pressure once a week and driving in like “old grandma style” in straight line mostly and long distances.
    Most I get was about 75,000km out of Michelin Agilis61 on Vito van city driving and a lot of roundabouts.
    So, it is actually quite possible.
    Adelaide hills, SA
    Was it from Bob Jane Marion?
