Originally Posted by
Silver Caravelle
Hi Crell,
If it can be first established whether it is the multi ribbed v belt for a accessories ( alternator etc) or the actual timing belt. The screeching sound might be the multi ripped belt, which would be a better outcome and need changing and possibly the idler pulley (s).
A timing belt is in my view not going to exhibit a screeching noise. If it it was to jump a few teeth, it would potentially damage engine quickly. If you suspect it is this, don't start or drive it; get it transported to a service place. Typically a water pump is changed at the time of a timing belt, tensioner etc change whilst pulled down.
Hopefully it is just the multi ribbed belt!
All the best.
Scott.
