You also should look into getting what vw sell as a "Robustness Kit " this is a VW made divider which will save your engine from major damage if the serpentine belt lets go . There are some who have found out the hard way when it happens , my mates one was at a workshop for a auto repair and they started the van up to warm the engine , a few minutes later they found the engine had stopped for no reason and then found the belt had tangled with the timing belt causing a few grand in repairs to the engine . The following day I booked ours in to do its belt and fit that kit so we did not have the same result , VW should have fitted the kit to all of them but there was no recommendation by them .
