Results 1 to 10 of 17
Thread: Timing Belt
    NSW
    Timing Belt
    Have just clocked over 100k in my10 103kw TDI T5. When should I have the belt changed?
    I do not go near VW for servicing usually but should I for this? Also do you change anything else when doing this job on the 2L. ie water pump, belt pulleys/bearings tensioner etc. What is the usual cost approximately?
    Thanks in advance
    Mt Cotton
    If its like most of the T5,s early and late other than the AXE engine [ no belts at all ] then yes belt / pump /tensioner would be the best thing done together .
    Sydney NSW
    Timing belt will start to get noisy soon, if it hasn't already, this should be done at 105k, there is also a robustness kit available, they should offer you this as well. There was a problem with all t5s 2010 onwards with not having a timing cover and poor quality pully and tensioner, the robustness kit gives upgraded components. I would get this done at the dealer.
    I think I payed something like 1400, the robust kit was 480.
    Sent from my HTC_0PJA10 using Tapatalk
    2011 T5 4MOTION Duel Cab Optioned up.
    Apr 2013
    Upper Gully VIC
    I got my 2010 diesel T5 timing belt replaced at 104,000 with a service. My water pump was replaced too as I was told it had started to leak. My mechanic advised me to replace the timing belt early.
    I read the service schedule and I believe the 2010 diesel has the toothed belt with the tensioning roller? If so the interval should be 210,000km. Apparently that was increased from the older models without the tensioning roller which is 120,000km. If you have the tensioning roller in dusty conditions it is also 120,000km but I don't drive on dirt roads. While it's not in the service schedule I also read "or 4 years" which means at 5 years I am due.
    Surprisingly my mechanic says the 4 year thing is rubbish. But he said his advice still stood that I should replace it early and remove that risk. He is not a VW mechanic but he reckons he is experienced enough when I have asked him. But he did miss the symptoms I reported before the axle broke. Family members have used him for 15 years without any other incident. Sometimes wonder if I am his cash cow. However I took his advice and not the risk. There was nothing said about the "robustness kit" but I'll ask next time I am there.
    I noticed after the timing belt was replaced the engine whine you hear at low speeds had got louder. I was told if that doesn't change then it's just the new belt and/or the setting that was chosen. I've got used to it now but it was definitely different to my now very cautious T5 owners ear.
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by stevan View Post
    Thanks in advance
    105,000kms or 7 years.
    Do the belt as a kit, with new tensioner and idlers.
    Definitely do the water pump. They always leak on these.
    Independent VW specialist at a minimum.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mt Cotton
    You can take some parts of VW,s servicing schedules with a pinch of salt as they were written in Europe and because they do not test here in Australia the real world is very different to the testing done at the factory or on road in Europe . You only have to look back at the Tiptronic auto VW fitted to the first series T5 they believed the auto fluid never needed to be changed . I proved that theory was totally wrong as the fluid inside ours was black as night and had formed a lovely sludge on the inside of the sump which cause the auto self detonate . If you doubt my word take a look at the new T6 what sort of engineer who SHOULD have come to Australia for testing was allowed to put the drink holders in the top of the dash right next to the windscreen . Might be fine for coffee in Europe but your cold can of drink will be nicely heated to hot within a matter of minutes .
    Dec 2008
    Sydney/Canberra
    You can run yours until the belt breaks, and smashes the cylinder head to pieces if you like, but I prefer to stick to the manufacturer's service schedule, and recommend advice that ensures a customer's warranty will be maintained, in the event of a failure.
    '01 Beetle 2.0
    Adelaide hills, SA
    The 7 years is for sure long enough time for the belt that also contain the rubber and perishes over the period of time. There is absolutely "0" chance that the engine won't be damaged when the timing belt brakes.
    Mt Cotton
    I would like to clarify what I said , it was not to give the impression that I would ignore the scheduled servicing from VW but to do it sooner rather than later as I said Australia,s climate is very different to Europe,s climate so prevention is the better option so go early rather than later .
    May 2006
    Adelaide South Australia
    It's interesting that in the UK, for the T4 at least, the VW cambelt change recommendation is 4 years whereas in Aust. it's 7 years.
    Maybe the UK cold climate makes the rubber more brittle.
    Numerous Mk1 Golf diesels
