Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Temperature gauge
    Jun 2014
    Adelaide, South Australia
    Temperature gauge
    So my t5 has power everything, windows , mirrors, locking etc etc but no temp gauge!
    What's my best option to rectify this?
    Sent from my windows 8.1 phone via tapatalk
    Mar 2013
    Brisbane QLD
    Becoming standard now on most new cars
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mt Cotton
    Yes I agree too many vital gauges being replaced with a some almost useless lights . I have fitted one of those HUD displays it connects to the OBD port and gives several bits of info whilst driving , tacho /fuel usage/ speed / overspeed in gears and you can set your own temperature level to give warning sound and sign which you can see right in your line of sight , some models have other features as well . I know its not as good as the old temperature gauge but it's better than nothing I suppose . Available on Ebay from $46 up to $115 . Lack of gauges etc becoming standard on new cars worries me especially with the fact that when we received our new T5 it came with a sort of cryptic message that told us that VW's seem to use more oil between services than I we would be used to , even the dealer told me that if the oil level is low between service we can call in and get a free top up , yes so if the oil light comes on and we drive the 40 odd kays to the dealer and it blows the engine who pays ??? . I am not alone with the oil business over on VW's Facebook page it seems to be well documented that several VW models use what seems excessive oil from new .
    Adelaide hills, SA
    Please, let's keep this one on topic, which is, the missing coolant temperature gauge.
    I'd prefer to use direct measurement from the coolant temperature sensor.
    Automobile Multimeter Gauge for EGT, Boost, Water/oil
    Other option is the scan gauge.
    Dec 2008
    Sydney/Canberra
    Temperature gauge or not, quite often the driver will know best, ignore all visual and audible warnings, and keep driving until it stops.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    I don't believe that's the right reason for ommiting the vital gauge.
    Mt Cotton
    Sorry transporter my oil comment was a bit off topic , I will add here as a youth growing up the temp gauge was absolutely vital to one knowing how their car was working . I would suggest that modern cars and their makers are probably more reliable but temp gauge is a no brainer and would save some heartache . When our first T5 threw up a temp warning light I was bamboozled as the water level was down {the usual water pump problem} but the engine was showing normal temp Umai is right some will drive on regardless but in my case 300 kays from any help I topped up the water tank and then watched the temp gauge like a hawk until I got home . The HUD I have seems close to the unit you have shown .
    Jun 2014
    Where would I mount that in the t5 transporter?
    Jun 2014
    Also what bud are people recommending or using with good temp readouts?
    Mt Cotton
    The HUD in our van is a small unit which sits flat on the top of the dash a cable goes around the end of the dash and plugs into the diagnostic port just under the dash driver side , it reflects the image onto a semi clear plastic piece that sticks to the inside of the windscreen . You can see the images without taking yours eyes off the road , whilst I have not had a temperature warning as yet I would imagine it is the same sort of warning I get when over revving it gives a sharp beep tone and maybe a temp sign comes up on the screen but not sure as I said . This is the same as ours but a newer version .LED CAR HUD Head UP Display OBD II 2 Speeding Warning System Fuel Consumption | eBay
