Results 1 to 10 of 16
Thread: Tailgate Tyre/Jerrycan carrier.
    Mar 2014
    Gracemere Q
    Thanks for the suggestions. I like the idea of being able to open the tailgate without having to swing out a tyre carrier as well.
    Yes the gas struts definitely have to be upgraded.
    The second photo showing the one using that adjustable tie down track looks possible to make. I think the track is held to the door with nutsurts and adhesive. It looks very neat.
    This one is Canadian and is made by Gary Lee for the T4 tailgate. May be able to be modified for the T5. The swing-out versions he makes for the T3 are really well made.
    Bruce CQ
    Tailgate Tyre/Jerrycan carrier.-img_0605-jpg
    Aug 2019
    Perth
    Quote Originally Posted by Big Bug View Post
    Bruce CQ
    Do you need to drill into the tailgate to mount this or does it clamp to the edge of the doorskin?
    Trying to copy these ideas from the T4/T5 to adapt to my Holden Adventra:
    Tailgate Tyre/Jerrycan carrier.-addy-png
    Mar 2014
    Gracemere Q
    [QUOTE=Pricey88;1309495]Do you need to drill into the tailgate to mount this or does it clamp to the edge of the doorskin?
    That Gary Lee version hooks over the top of the door and is tightened by the clamps on the bottom. I ended not going with that version as it was way too heavy so I discarded it and went with a lighter version.
    Tailgate Tyre/Jerrycan carrier.-dsc04536-jpg
    The Airline Track/Versa Track attaches to the door with stainless steel bolts, nutserts and adhesive. Then the frames are bolted to the track. I only lightly load it, 10 litres of water, 10 of diesel when needed, Maxtrax and shovel. Worked well on the Cape York trip. I based it on this design. I
    [IMG]https://uploads.tapatalk-cdn.com/
    20200126/28a8e35e70fd4adda6297804420e7d99.jpg[/IMG]
    I’m ever mindful of having too much weight on it as the door hinges are fairly small.
    Bruce CQ
