Just wonder if this model will survive rough roads
https://s-media-cache-ak0.pinimg.com...33a366e655.jpg
Saltd0g, I have a different version of that tyre carrier and I find it very cumbersome. Now the Tyre Trek does look a lot better. The carrier I have weighs about 50kg unloaded so that is a lot of weight hanging out the back of the van, then put on two jerrycans and a tyre is a fair amount of weight. The Tyre Trek appears a lot lighter than that and is easier to mount with the tightening bolt at the back, I need about a 400mm extension on the socket spanner to tighten mine.
I will persevere with the tailgate idea and see how it works or not as the case maybe. I saw the Tyre Trek after I bought mine but isn't that always the way.
Bruce CQ
I bought a Tiregate and modified it.
Its ok but clearance with tailgate when opening is very tight. I had to make shims up to avoid contact.
It was flogged out over time and flaps around a lot.
If doing it again I'd design my own using a trailer axle system like many tyre carriers on 4wds, but still mount off reece hitch.
[QUOTE=Pricey88;1309495]Do you need to drill into the tailgate to mount this or does it clamp to the edge of the doorskin?
Trying to copy these ideas from the T4/T5 to adapt to my Holden Adventra:
That Gary Lee version hooks over the top of the door and is tightened by the clamps on the bottom. I ended not going with that version as it was way too heavy so I discarded it and went with a lighter version.
The Airline Track/Versa Track attaches to the door with stainless steel bolts, nutserts and adhesive. Then the frames are bolted to the track. I only lightly load it, 10 litres of water, 10 of diesel when needed, Maxtrax and shovel. Worked well on the Cape York trip. I based it on this design. I
[IMG]https://uploads.tapatalk-cdn.com/
20200126/28a8e35e70fd4adda6297804420e7d99.jpg[/IMG]
I’m ever mindful of having too much weight on it as the door hinges are fairly small.
Bruce CQ
I will have another go at sending the photo.
