Results 1 to 7 of 7
Thread: T6 Clunk in Front Suspension.
    May 2017
    Vic & Tas
    Last year my 2017 T6 developed a clunking noise somewhere in the front drivers side - can feel it through the floor when it happens. Usually happens if there is a dip in the road (rather than a pothole), doesn't happen all the time. I've had the local workshop look at it a couple of times - all then can suggest is an internal fault in the front shocker. Has anyone else had this (or similar) problem? Any ideas?
    2017 T6 2lt Diesel Manual
    The only person to get everything done by Friday.......was Robinson Crusoe.
    Feb 2008
    Adelaide,Oz
    Are you sure it's not a driveshaft?
    T5's had a prob where the driveshaft splines would wear from lack of lube, causing clunks. More prevalent in manuals than autos, i think.T6s you would think should be ok but with VW you never know
    Can you drive the same bit of road, and see if it makes same noise in neutral or with clutch pressed
    Steve
    04 T5
    Mt Cotton
    My T5 wore out the shaft so badly the teeth were twisted sideways , it mostly made noise when cornering . But in saying that it could be the top of the front struts or the struts themselves .
    May 2017
    Vic & Tas
    Well I certainly hope it's not the drive shafts - it's only done 30,000k.
    "Can you drive the same bit of road, and see if it makes same noise in neutral or with clutch pressed?" - I'm afraid it's not as predictable as that - usually happens on dirt road and travelling fairly slowly.
    Arrawarra
    I've had a few not so great sounds coming from my front suspension when hitting a small bump or pothole & i've come to the conclusion that a bit of gravel from road resealing or gravel road has been crushed as the suspension compresses. It's happened a few times now & is usually after a stint on gravel or after driving on a recently resealed road. Usually only does it a couple of times then the sound goes away.
    Current: MY18 TRANSPORTER CrewVan, Indium Grey
    Previous: MY10 Tiguan 2.0TSI, Silver Leaf, APR StgII tune + many mod's
    Mar 2008
    Quote Originally Posted by MGV View Post
    Ditto. I had a bad clunk that came and went after about half an hour of drive. It has never came back. I concluded it was a large stone thrown up by the tyre into the strut spring base some where.
    Nov 2007
    QLD
    Have you checked that nuts on the end of the stabilizer bar connecting rods, when one of mine was slightly loose it caused a noise like you describe.
