Page 15 of 19 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 182
Thread: T5 transporter aftermarket radio options
  1. #141
    Apr 2013
    Upper Gully VIC
    Comparison time Chinese head unit DAB+ AM FM radio Bluetooth standard [No Coding required ] plays DVD,s MP3 discs Mp4 WMA and other Discs region free . Digital TV / GPS standard with concealed antennae up under dash . Forward collision camera connected to head unit and stores footage to a SD card $20 . Reverse infrared camera with guidance lines $25 WiFi connection to local network . Mirror Link to IPhone or Android . Monitor engine performance and stats via Bluetooth module to diagnostic port $25 . Built in Graphic equaliser dedicated subwoofer output and extra RCA outputs for amps and also RCA inputs for other devices and also two USB connections with supplied cables . Multiple screen savers . Ok you get the picture why I like them and all this for less than $450 when you consider a RNS system in 4 years time the system itself along with GPS maps will be so far out of date , meantime I can replace the head unit for the most up to date model with all the apps and functions etc every year and still be better off dollar wise . Yes I have read some reports of problematic ones maybe I have been lucky but so far all good .
    I was thinking of giving this full blown suggestion a go.
    Due to time issues - and automotive technical incompetence - I was considering just handing all the parts to my auto electrician.
    Was hoping you could please provide a current link for where you would purchase this from - to help me reduce the risk of getting a problem one.
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
  2. #142
    Apr 2013
    Upper Gully VIC
    Or is this the place you use for all of it?
    https://www.erisin.com/
  3. #143
    Mt Cotton
    This is the very latest model with Android 6 operating system . https://www.erisin.com/erisin-es6405...adio_p760.html I got my new one last week as I decided to upgrade my wifes van as she had an older one that did not have DAB radio . You will find that they will direct you to their sales person Tamer email here you can quote the number and ad the extras you want so he will give you a full quote incl delivery
    Tamer Yehia <tamer_comm_eng@yahoo.com>
  4. #144
    Apr 2013
    Upper Gully VIC
    Thankyou very much.
  5. #145
    Apr 2013
    Upper Gully VIC
    Was wondering if you have installed your new unit yet?
    I've sent off my email. Have just asked for prices for the front and rear cameras and the engine performance monitor. Were there anything else?
    Do I need to order the VW antenna amplifer you mentioned too?
    https://www.erisin.com/erisin-es068-...r-vw_p300.html
    And I assume there is some sort of VW adapter/decoder? Is that included with the unit?
    I'm trying to do a crash course learning about head units. Never had one.
    If I get one of these it means I forgo (licenced at least) Android Auto and Apple CarPlay which is a shame. And not sure whether this really does wifi 2 way mirroring.
    But if I want all that I'll have to spend at least $1,100 on say a kenwood ddx917ws.
    It's also a shame about all those not so good reviews about Erisin. Is what I read correct that all these China brands are just the same units rebadged? (Eonon, Joying, Pumpkin). Joying seem to have the best rep.
  6. #146
    Apr 2013
    Upper Gully VIC
    Here's a current quote for one of these for anyone who is interested;
    Erisin ES6405V 8" Android 6.0 Octa Core Car Multi-media stereo GPS Sat DVD DAB+ for VW 8-Core Autora - $325.00
    Erisin ES550 Universal 1.3MP USB Camcorder Recorder for Android Car DVD - $14.00
    Erisin ES580 CCD HD 170° Mini Car Rear View Camera - $11.00
    ES350 Mini ELM327 OBD2 V1.5 Car Bluetooth Scanner Android Auto Scan Diagnostic Tool - $7.00
    Erisin ES068 Radio Antenna FAKRA Adapter Amplifier for VW - $9.50
    Shipping - $99.00
    Total - $465.50
  7. #147
    Mt Cotton
    I would not worry about the engine monitor it,s more of a novelty although it does have some interesting readouts . but for $7 its a cheap toy . What year is your van as the early ones don,t need the antennae adaptor , later models after 2010 have dual connectors . I did not use the original antennae as once you remove the original head unit it does not seem to work with other brands .I fitted roof mount antennae from a Nissan Xtrail bought from Autobarn . The unit comes standard with a can Bus adaptor so it just plugs into the factory plug no coding needed .They do have Smart phone / iPhone mirroring but I just let Bluetooth do the job much easier .The unbit you mentioned Kenwood will only probably fit and early model T5 as the later has tapered sides , I also noticed it does NOT have GPS you only use a GPS antennae for linking to your smart phone , so you would be using download data for GPS on your phone . The Erisin has GPS built in with the latest Igo mapping etc .
  8. #148
    Apr 2013
    Upper Gully VIC
    The unit you mentioned Kenwood will only probably fit and early model T5 as the later has tapered sides. I also noticed it does NOT have GPS you only use a GPS antennae for linking to your smart phone , so you would be using download data for GPS on your phone. The Erisin has GPS built in with the latest Igo mapping etc .
    Thankyou again for the further info.
    Further to the Kenwood. First I linked the wrong model. That's just for Toyota and it is a wide screen with fascia. This is the generic model that will suit a VW T5 - Kenwood DDX-9017DABS - still about $1,100 - plus a $200 kit to install.
    (until the 11th June you can get 20% off the $1,100 on ebay from ryda - which is very tempting)
    From my research - and I am no expert - this is the best name brand value and technology unit in it's price range (there is a cut down version for about $750 - or the cheapest name unit being the Sony XAV-AX100 currently $560 from JB plus a kit)
    Yes it doesn't have gps - but that is part of the decision - these units with Android Auto & Apply CarPlay means you let your phone do all the work including gps and all the apps - so you don't have to upgrade your head unit as often because it just does the basics and doesn't duplicate what the phone can already do -assuming you are probably going to upgrade your phone regularly anyway.
    But it is still $1,300 ($1,100 after discount - $1,000 after gst) - compared to $450 for the Erisin.
    I've now got some thinking to do.
  9. #149
    Mt Cotton
    I suppose its what you want for me I like the idea of the built in GPS as I can stream Bluetooth music or listen to DAB+ digital radio and see my map in the GPS all at the same time all on an 8inch screen . Yes I was a bit confused at the specs on the one you posted makes sense now . Good luck with you decision .
  10. #150
    Apr 2013
    Upper Gully VIC
    As I said earlier, I really appreciate you taking the time to share your knowledge. I've started this process with zero knowledge about head units. Now I feel I have a pretty good idea about what is going on...at least enough to make my own decision properly (as opposed to buying a T5 just because I liked how it drove - and of course VW's will always be reliable - especially commercial ones rme).
    I've never used a real gps before so I can't really compare - have always been happy enough with google maps - but I understand that others would only ever used a dedicated one.
    As you mentioned earlier in the thread - the head units that do everything - also get out of date pretty quickly - which is why you said you're are happy buying a fully featured chinese unit more frequently.
    If I was buying personally I would have no hesitation about buying the Erison - well apart from those reviews
    But not only is it a business expense for me - I am expected to understand the technology involved by many of my customers - the freebie questions that come with the job - and now that I understand the chinese units don't support licenced versions of the apple and google car software - that is a fairly big downside for me (I hate learning new software - but it's a fact of life at this stage).
