Results 1 to 4 of 4
Thread: T5 2011 manual geqrbox oil
    Sydney NSW
    T5 2011 manual gearbox oil
    I have 67000 on my 011 model t5 4motion duel cab, I have allways had it serviced as per requirements. I am concerned that they never mention changing the gearbox oil, should this be done? And can I do it myself.
    Are the bolts easy to access? If I can do it myself what is the best oil I can use, grade ect ect, and how many ltrs should I need.
    Any advice would be appreciated.
    Sent from my GT-I9505 using Tapatalk 2
    2011 T5 4MOTION Duel Cab Optioned up.
    Dec 2008
    Sydney/Canberra
    Volkswagen says G052171A2 oil, but doesn't mention a viscosity.
    Liqui-Moly says it'll take a GL4-grade 75W-90, and you'll need 2.7L.
    Drain and fill plugs are easy to get at. Drain is on the bottom, filler is on the front side, between the gearbox and radiator fans.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    That original oil is very low viscosity, lower than A/T fluids. I use Penrite SinGear70.
    Sydney NSW
    Thanks guys.
