![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
gldgti
Hrrmmm The shop doesnt have any real excuse because they should have all the correct tools (the dial gauge and adaptor) but you do need to be extremely careful even with the right tools because you only need to be out by a little to make a big change to performance, economy and especially cold starting.
As I said earlier in this thread, VagCom is needed to set the timing. The dial gauge & adaptor aren't good enough for the TDI. The engine needs to be above 85C & running & the timing plotted on a graph.It needs to be spot on to start at the touch of the key.It takes time to set it properly & adjusted carefully.
Numerous Mk1 Golf diesels
