Results 1 to 4 of 4
Thread: T4 Auto to Manual Transformation
    Evripos Guest
    I own a Eurovan GLS 2001 with a AXK 2.8L 24V VR6 engine and a 01P 4-speed automatic transmission. I was wondering if anybody knows if it would be possible to fit a manual transmission to this van. After some researching I have found out that the engine AXK is the same as the AMV and AYL engines.
    Yanni, Philly, USA
    Jun 2006
    with the dust and flies in western Victoria
    The simple answer is yes......however you'll probably have to import a box from Europe. So it'll be expensive.
    One of the lads on VWvortex has a T4 with this conversion.....he bought it after the conversion (done for a show car) and was told that to do the work was something like US$7,000 (?).
    Camden, Sydney
    You would be able to do this.
    All Transporter boxes are the same, manual 2L, 2.5L, 2.8L.
    The bellhousing will physically fit on your motor.
    You need a flywheel from a VR6 manual Golf, and clutch
    Manual t$ Gearbox, TDI one is good if you can get it, hydraulic clutch setup from a manual T4 and shifter mechanism from the same.
    I have a couple of T4 manual boxes here, but freight could be pricy
    Evripos Guest
    Can you be more specific on which tranny code I can look for getting? Don't forget my engine is the AXK coded one. Is there an article/thread on the Vortex "project"? Which boxes do you have available? Are they 5-speed or 6-speed?
    Yanni, Philly
Similar Threads
  1. VR6 : Golf vs. Passat
    By Putt-Putt in forum Mk3 Golf & Vento
    Last Post: 29-09-2006, 07:41 PM
  2. Auto Lockout on Mk3
    By Golf Loon in forum Mk3 Golf & Vento
    Last Post: 22-09-2006, 07:10 AM
  3. VR6 in auto or manual?
    By dj_daniel88 in forum Mk3 Golf & Vento
    Last Post: 09-03-2006, 06:38 PM
  4. Auto to Manual Conversion on a Mk2
    By Golf Loon in forum Mk2 Golf & Jetta
    Last Post: 02-08-2005, 07:25 PM
