Results 1 to 10 of 11
Thread: T4 2.5 petrol BAD oil Leak
    Apr 2013
    SunnyCoast
    BAD oil Leak started very slowly a couple of weeks or so ago. T4 2.5 petrol 1998 model
    Thought it might be coming from the oil filter , so changed that but still running down the outside of the new oil filter only when the motor is running. Difficult area to see when filter is in the way. If i take the filter off, I cant run the motor to try see where the oil is coming from. Getting much worse. Any ideas ? Are they known to leak in an area adjacent to, or above the oil filter?
    Jun 2006
    with the dust and flies in western Victoria
    Not very familiar with the petrol engines but sometimes the filter mount is a seperate component with a gasket between it and the engine. Perhaps that gasket has given way?
    Aug 2012
    Qld
    I had a bad oil leak a few years back in my T4 2.0L petrol and they found the problem was the oil pressure switch ... don't know if this is located in the vicinity of your leak?
    Actually did a bit of googling to see if this pressure switch is near the oil filter and came across this which seems similar to what you have described 2.5 acu petrol engine oil leak - VW T4 Forum - VW T5 Forum
    Apr 2013
    SunnyCoast
    Thanks so much Seano and Gold Coaster. Sounds very much likely to be the problem. I'm in central Qld at the moment. Any idea where best to order / get this part from? Will try to find a schematic first , so I can order the correct part number. ie oil filter / engine block gasket.
    Apr 2013
    SunnyCoast
    Found it . Goes by different names but this is it . Wish I could get it for uk price but nah will have to get sent from Sydney so will be a few day and price won't be good but that's life . Engine Oil Cooler Seal Oil Filter Housing to Oil Cooler Seal 59 x 5mm VW T3 VW T4 VW T5 VW Caddy VW LT VW Crafter 038117070A
    Apr 2013
    SunnyCoast
    May 2006
    Adelaide South Australia
    I was going to reply to your thread, but like Seano I am not familiar with the petrol version. I did try to look up my Etka but for some reason couldn't get it to work properly.
    What amazes me is the no. of cars/vans that the kit fits, over thirty years. Well done VW.
    Numerous Mk1 Golf diesels
    Aug 2016
    NSW
    Parts are cheap in the UK.
    No wonder all the Pommies are keen to grab Transporters when they get here.
    Must be a huge shock to see the parts prices in Australia.
    2018 Crafter Runner
    T5.1 6sp manual.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by LogicprObe View Post
    Depends where you shop here I guess :
    Oil Cooler O-Ring - Euro Revolution
    Bigger issue is trying to find a cheap house in Sydney !
    Bug_racer supports the rebellion of the euro revolution
    Aug 2016
    NSW
    Quote Originally Posted by Bug_racer View Post
    Mate!............I sold mine and moved to The Gong!
    2018 Crafter Runner
    T5.1 6sp manual.
