I owned a caravelle til mid 2000 ( ex took it as part of the divorce settlement) the engine was always prone to weeping about the head/ cranckase joint.
Definately have to be on the ball with cooling system maintenance ( think it was using G12 ??) and the correct way to bleed the air out of the radiator..check the oil water intercooler BTW...mind you , the volume of water coming thru its likely a stud or the case has corroded thru..
If I still had the vehicle it would likely be running a subaru engine by now..
