There are arm rest kits on ebay Germany.
eBay: armlehne t5 vw
Is anyone fed up with their comfort seats?
I would like to swap the stock seats out of my van and get something better with arm rests. saw a van (mv or crew) up on the central coast that looked like it had recaros installed. I'm doing 12hr trips and would love the armrests and some more back support.
so. anyone looking to shift some comfort seats?
or. anyone know a good aftermarket seat i can stick in easy for a good cost.
or. anyone know anywhere that wrecks mv's and the like that would have good seats?
cheers
I have fitted folding armrests to both front seats on both our T5,s I was lucky a friend of mine who owns his own Motor Trimming business on the Gold Coast used to do recover work for a motor home company and they used to supply different folding armrests from the standard ones which were on the seats . I was able to get the standard ones and retrim them and fit them myself with very little trouble all that was required was to drill one new hole in the side of the backrest frame and that was it the armrests are able to be adjusted in height with a simple knob on the underside . As for back support I also fitted some pump up lumbar supports these fit under the foam of the backrest and you can inflate and deflate them to the required setting with a small hand ball pump , they are real good for lower back support on long drives . The armrests cost me $15 each the pump up lumbar was about $35
Hi < I bought a set of armrests off ebay from the UK. They came with everything required to fit and took about 30min to do each seat. Very easy to do.
They are actual VW armrests and where the same colour grey as my seats.Other colours are available too.
They make a big difference on the long trips.
cheers
