Results 1 to 4 of 4
Thread: Strange brake hissing noise!?
    Jun 2019
    MOUNT BARKER SA
    Hi 2003 T4 Transporter 2.5 @ 220,000kms here. I have developed a loud hissing noise in the cabin over the last couple of journeys which goes completely when I apply the brakes but returns once off the brakes? It sounds like a leaking air hose. No loss of braking effect or any obvious cause or leak. Noise is less obvious inside the engine bay. Anyone had this or any thoughts as to what it may be? Thanks in advance, love this van.
    Mar 2008
    Hi there,
    It is possibly a brake booster leak possibly in the brake booster diaphragm somewhere where it meets the brake lever through the firewall. Or somewhere along the brake booster vaccum line to the brake booster. Check booster hose has not popped off or split. Also check there is no brake fluid loss with a leaking master cylinder.
    Regards,
    Scott
    Jun 2019
    MOUNT BARKER SA
    Thanks Scott, turned out to be the brake booster master cylinder rear seal. Out now and hoping to get it rebuilt.
    Thanks for pointing me in the right direction.
    Dave
    Mar 2008
    Cheers Dave. Glad it has been ascertained.
    Regards,
    Scott
