Results 1 to 10 of 17
Thread: Steering wobble?
    Steering wobble?
    Dear All
    2008 auto T5 Tdi with 135,000 k's taking a sharpish left hander a little above the posted 55kph recommended speed and on exit, still under a trailing throttle, felt a pronounced wobble/shudder in the steering. I immediately stopped thinking I had a loose wheel or flat tyre but could not find a thing. Started off slowly and the wobble was obvious at 20km/h so pulled over and spent 15 minutes under the van looking for problems but couldn't see anything obvious. Got going again slowly building up to 60 and nothing not a thing. Drove home without a problem.
    I've had the van since 90,000 k's and when taking off under light acceleration I've often felt a mild shudder like a gearbox or engine mount may have been cracked but have never looked into it (laziness). Van is scheduled for a major service on Wednesday but can anyone suggest a possible cause of this problem?
    Mar 2008
    Hi there, I have notice something similar (2008 TDi), veering slightly to the left under full acceleration and feel a mild shudder under light acceleration. Also Steering has a noticeable noise when steering wheel turned to the right for a few turns only, then fine. Mine is heading in for a service. Wondered if it might be a ball joint or something.
    Cheers,
    Scott
    Scott
    I read somewhere that the noise in the steering (usually at low parking speeds) is dirt captured under the top of the struts and more annoying than a problem.
    Double post
    Mt Cotton
    Whilst it may be unrelated its worth checking , our T5 at around 70-80k displayed shuddering which we could feel through the steering wheel whilst under acceleration . Ours turned out to be the beginning of the end of the auto as the clutch packs were obviously slipping and the shuddering would be transmitted back through the drive train to the steering wheel . At the point of its worst condition before complete failure the auto created shuddering at different speeds - cornering etc. I am probably wrong , and hope for your sake I am , but I hope you do find a precise and simple explanation .
    I know the T5 has a bad rep re: auto's but mine seems OK at this point - No noticeable change in personality, changing down without clunking etc but it has flared since I picked it up. Fingers crossed.
    Michael
    Mar 2008
    Quote Originally Posted by Red Bicycle View Post
    Scott
    Hi Red Bicycle, Thanks, good point. I will give a good hosing up there to see if it makes any difference.
    Also I have loosened and re tightened the front wheel nuts. Very very slight play in the right hand front wheel side, if I grab the wheel firmly.
    60k service tomorrow.
    Regards,
    Scott
    Mt Cotton
    As I have just posted on another thread any auto service with the Tiptronic should as I have discovered have a new filter done or its bye bye $11000
    May 2010
    Kilmore, Vic
    Shop around first
    M
    Just dropped it off with the mechanic. His suggestion was it could be the drive-shaft but very difficult to diagnose and expensive to remove for testing.
    I guess I'll have to wait for a recurrence.
    Michael
