Vw should still cover it if just out of warranty??
Worth a try especially as they serviced it ???
'07 Transporter 1.9 TDI
'01 Beetle 2.0
It will be going to the dealer on Tuesday. Once they actually diagnose the problem we can enter into talks with vw if need be
I'll keep you posted
Any news Big Boy
VW knows this is a problem and your service centre should of informed you a modified cover is available and needed to be fitted at the last service. The way I see this the fault lies with both the dealer and VW,call vw customer service and ask for a case number ....BUT MOST OF ALL YOU MUST STATE THIS VAN IS NOT FIT FOR PURPOSE you should have been informed of known issues through TPI's and given the option to retro fit the improved item.....I know of many engines that have been covered with VW at no cost to the customer.DO NOT GO IN AND ADMIT LIABILITY....be prepared to fight by sighting the well documented issue world wide surrounding the timing belt failure. If this is a factory dealer who serviced you 2 months ago they should know better.....feel free to call me on 02 96792900
Valves are not the only issue as the camshaft itself twists, new cylinder head may be required......just ask upon disassembly if the engine needed to be rotated to allow access to cylinder head bolts....if so cams are twisted
I might have just had the same belt snap on my 2011 T5 Multivan? Got a pic in my thread next to yours about power steering, not sure about engine damage as I was driving, belt snapped and I lost power steering, engine was still running but I pulled over and turned it off. Getting it looked at on Monday.
