Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: So what is a coilover??
    Erskineville, NSW
    Quote Originally Posted by Red Bicycle View Post
    Thanks Brad
    I suppose I have two questions:
    1. Is the 'no drop' ride height of the Bilsteins the same as stock?
    2. What is a good compromise in terms of the benefits to handling from reducing the height above the road surface of the vehicle's centre of mass and available spring travel for our crappy roads?
    1) I've never fiddled with Bilsteins but on 2 other sets I've helped fit you could actually raise the height a fraction.
    2) It depends on the vehicle, spring rate, available suspension travel and where the roll centre is in relation to the centre of gravity (nb: I still don't have a clear understanding of COG & roll centre). I've set cars up with heavier springs at stock height & they've been brilliant - but that's how the owner wanted it.
    Your best idea is to set the ride height where you want it & see how it goes. If it's a bit crashy or appears to be belting the bump stops a lot then lift it up. Keep in mind that radical changes of the front height will require a tweak of the toe setting.
    Some people are more than happy to lower their car into the weeds and have their fillings shake out.
    Oct 2010
    Melbourne, VIC
    Lower CoG is rarely a bad thing. The problem when doing is that achieving it without major suspension changes will ruin everything else (including the roll centers)
    I linked to some good posts on the subject here - Does your VAG handle? It depends...
    Resident grumpy old fart
    Mar 2014
    Greenbank,Qld
    Most comments above related to lowering the ride height; my intent/want is to raise the body for increased ground clearance. I have T5 4 Motion and am converting to a camper. "Lift kits" don't seem to be readily available under that name and all advice so far from those who should know (VW service and a couple of mechanics), tell me that a lift kit will upset CV joint angles and cause other problems. Essentially, all have advised something like a Bilsteins Coilover installation and wind the things up to create greater ground clearance. My online searching tells me that Pedders do a coilover and King's Springs on the Gold Coast do something similar. So, for that increase in ground clearance, am I on the right track?
    Iza
    Jun 2012
    NSW
    T5 Suspension codes
    Hi Red Bicycle,
    This list might be handy FYI:
    T5 Suspension codes, from - JEWUWA | T5 T5 German Board - member, Translated from German. Words in italics are my edits.
    For the Multivan T5 there are different undercarriages: (Suspensions) (I guess some of these didn't come to Oz)
    1BA - Suspension and damping Standard: This is the standard suspension for the priority use on paved roads. against a closed vehicle (Vans) here is the Multivan already 2cm deep. (lower)
    (Compared to panel vans, the Multivan is 20mm lower)
    1BJ - * suspension / damping reinforced front and rear: This chassis is designed for use with bad roads (eg gravel). The Multivan here gets stiffer springs and stiffer dampers. This, however, the Multivan is again compared to the standard suspension 2cm higher and thus on the same level as a closed vehicle (Vans).
    1BB - Suspension and damping in bad way design: This chassis should be selected in areas with hardly any paved roads. The Multivan gets hardest by springs and dampers hardest. The Multivan is then higher than a normal Multivan and at the same level as a closed vehicle (Vans) as 1BJ 2cm.
    1BV - Sport chassis: This sports suspension is exclusively reserved for the Multivan. It is important for drivers with sporting ambitions. The benefits can be seen by reduced body roll and increased roll stability of the vehicle. Compared to the production model of the Multivan is a further lowering of 2 cm so. Thus, the Multivan is a total of 4 cm deeper than a closed vehicle (Vans). Thus, the suitability garage is at the height further improved. For use come harder and shorter springs and stiffer dampers. The sta-average front is 25mm and rear 28mm.
    2MD - lowered suspension: By this suspension leads to a lowering just for aesthetic reasons. Benefits can also use the garage better fitness (analogous 1BV). The springs are the Multivan the same as in 1BV sports suspension. Dampers are at the state level but adjusted the damping behavior is the same chassis 1BA. For all vehicles (except Multivan) the fact that the admissible HA reduced by 50 kg.
    additional chassis, which are not offered for the Multivan. Please inquire for yourself what T5 versions are these:
    1BH - Suspension and dampers for vehicles with 3.2 t GVW: This chassis provides open a standard vehicle for Vans (closed & and Caravelle and Shuttle with choice of 3.2 t gross vehicle weight (GVW).
    2MF - Suspension and dampers (standard) and reinforced stabilizers front and rear: This chassis is not offered for the Multivan and is used in the other T5 for a lower side tilt the chassis and higher roll stability and lower sensitivity to side winds. In open bodies from certain building height, this chassis is technically necessary.
    2MG - enhanced cushioning and stabilizers front and rear with reinforced stabilization: ---
    2MK - Rear suspension reinforced: This suspension should during frequent load on the rear axle up to the max. Axle load are used. It is used to compensate the vehicle standing height (eg for Tool Trolleys)
    2ML - damping front and rear reinforced: This chassis comes only when open Vans used. and corresponds to the chassis 1BJ with closed bodies. Since the open bodies already the strongest springs are standard equipment, come here also only the dampers from 1BJ used.
    End of codes.
    I forget if B14 Billys have adjustable damping, but if they do then careful -trial / adjustment- is where you can gain a lot in ride /handling.
    Erskineville, NSW
    If you just want to lift it then get a new set of springs made that have an increased spring rate & a bit more length. They'll fit onto the existing suspension. A good spring maker like k-mac or Kings will know exactly what to do to achieve your goals.
    The CVs will be at a greater angle & possibly wear faster but how much do you intend to lift it?
    Also, is it still sitting at "factory fresh" height or has it settled a bit?
    Syncrotek
    Very interesting - the sport multivan is 40mm lower than my standard van - that sounds like a good starting point.
    Thanks
    Michael
