Today I fitted the 'modified' vacuum hoses as per Volkswagens TPI 2027520/13, to solve the 'moo valve' noises coming from within the engine bay.
Symptoms included the mooing noise and also when revving out in say 2nd gear the car would just lose all power, like it was losing boost, and then slowly pick it up again as you change up a gear.
Taking it for a test drive was an absolute revelation as it now pulls hard, on boost all the way into the higher rev's (did this as a test only because, yes I know they don't make power up there) and it does not lose boost between gear changes and the mooing has stopped!
A massive thank you must go out to Transparu on here for getting in touch with me about the issue after I posted a wanted add for a place to find the hoses online due to them being exorbitantly expensive here in aus, he not only found them.........in Czechoslovakia no less, then ordered, paid and sent them to me in Melbourne, all without wanting payment till I received them. Cheers mate.
My suggestion to anyone with this problem that hasn't got the upgraded hoses to do this before just replacing the N75 valves. I am not actually sure when they were issued as a new model factory replacement so it would be up to you to check.
Part number for both sets of hoses are as follows:
Bi-TDI CFCA engines
7E0129458N
7E0129458M
If you need the ones for single turbo just ask.
The VW Technical Product Information article is 2027520/13
