Update 23/10/20
Recent jobs completed as per above post was the UHF install with photos below.
Still unsure about the aerial fold down bracket and fitment location so it may change.
Next up was install upgraded Raised KVRR-18HD King Springs in the rear to compensate for added weight of the sound deadening and refit of the cabinetry.
I basically regained what I lost in height by adding the extra weight with the HD springs fitted, which is nice and will go well with the new 265/65R17 tyres I am getting fitted next week.
Here is a photo of the 3 different types of rear springs. The black one is standard VW fitment, the middle one is Raised King Springs KVRR-18 and on the left is the King Springs Raised KVRR-18HD (300-500kg constant payload).
As you can see they are all exactly the same physical height the only difference is the diameter of the spring steel therefore you can run them with a standard length shock.
Dimensions for them as follows:
Standard: 20.8mm
Kings KVRR-18: 22.4mm
Kings KVRR-18HD: 23.4mm
Actual lift is in the 35-40mm range on the rear with out any weight in the van. Loaded it is 15-20mm as my van now weighs it at nearly 2900kgs. The van now takes off with little to no squat in the rear and obviously rides higher too.
Next on the list is a set of Black Duck front seat covers. I've wanted these for years and left it way to late to save the drivers seat but alas they are on now and I think they look great.
I opted for their newer 4Elements version in Black over the older canvas style due to them being waterproof, removable and machine washable should the need arise.
Another job ticked off the list was changing out the front lower control arm bushes for a set of SuperPro Poly bushes with offset castor adjust for the rear set to get a better wheel alignment done as the van has always pulled left on the highway.
Even without a wheel alignment the van drives much better in a straight line and the steering response is much, much quicker.
While doing the control arm bushes I also replaced the left front strut top bearing as I hit a gutter at reasonable pace unexpectedly and it pretty much destroyed the bearing.
I have also got a Bowden's Own Bumper Repair kit to bring the old faded grey sun damaged ones back to life. Just waiting for a day where the weather is good for 24 hrs as you can't get them wet for 12hrs once it's done
Visually, with the new bigger tyres, I think it's going to dramatically change the look of the van, which I can't wait.
