Page 9 of 22 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 215
Thread: And so it starts.....my new T5 LWB Motion
  1. #81
    Apr 2013
    Upper Gully VIC
    Tried to read the link but the site's gone offline?
    t5-life.com
    Can I access the info somewhere else?
    What's the outcome?
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
  2. #82
    Aug 2016
    South Yarra
    Quote Originally Posted by aSimpleLife View Post
    t5-life.com
    What's the outcome?
    It's back up now.
    Finally VW have a master technician booked to look at my van on Monday 20th solely to diagnose and repair so I've been told.
    I will know more come Monday afternoon after my van has sat there for 2 weeks and nothing has been done.
  3. #83
    Jun 2006
    with the dust and flies in western Victoria
    Strikes me as a fuel/timing issue. Either way bloody inconvenient!
  4. #84
    Aug 2016
    South Yarra
    Quote Originally Posted by Seano View Post
    Yeah very annoying.
  5. #85
    queanbeyan, NSW
    Re bulbs, in my experience the cheaper "high output" globes are hit and miss. I've tried them in the past and they've rarely lasted that long. I've been running the top spec Narva globes for many years, NOT the blue ones, and won't use anything else. I've tried Phillips and can't justify the extra cost over the Narvas. Especially since the last set I got lasted >12 months, the Narva +120s I replaced them with have lasted longer.
    As for wiring the LED bar to a seperate switch, it's actually a legal requirement to have them switched. Not simply wired to come on with high beam, been caught in the past without a switch. I'm pushing my luck at the moment with my Citroen, while both sets of Hella Rallye 1000s are switched, the actual switches are in the engine bay beside the power distro box. Running wires in that thing is a nightmare, can't drill the firewall as it's double skinned and high strength steel and the main harness comes in just about under the floor.
  6. #86
    Apr 2013
    Upper Gully VIC
    Did you get a response yesterday? ...hopefully it's the least expensive/time consuming outcome.
    I was also curious...I think you said you came from a Hiace? ...was wondering what your reasons were for making the change...and what your current thoughts are about having made the change.
  7. #87
    Mt Cotton
    I can give you a couple of reasons for anyone leaving a Hi Ace , too narrow they always feel top heavy . Even though they are rear wheel drive they will easily lift one wheel off the ground around corners and roundabouts , nearly no frontal protection just a dash and windscreen scary to see how easy it would be to get some leg chopping done in a full frontal prang . Terrible ride very choppy with a tendency to bounce the rear end off the ground [ I was witness to this while following one over a rough road scary ] the poor sod nearly ended up sideways while the VW remained on track . Can,t comment on reliability but could it be worse than some Transporter Vans .
  8. #88
    Apr 2014
    Chelmer, Queensland
    Funny about that. I gave up on my 2 litre suitcase Kombi when a gate trailer jackknifed & stopped just before he hit me & went to a T4.
  9. #89
    Apr 2013
    Upper Gully VIC
    I can give you a couple of reasons for anyone leaving a Hi Ace...
    I was hoping you might not see my question tucked away over here...you've previously made me well aware of your views
    However the op mentioned he had come from a Hiace...and I was just interested to get his views...originally and now.
    I had been following this thread as a good news story...until I saw that tow truck...
    And as I prepare for tomorrows replacement of the passenger drive shaft...that was only replaced 18 months ago...I dream about my previous petrol engine made in japan vehicles...with their lack of comfort and safety...and older technology with less complexity.
    I just want a van to be a van...that I can trust to be reliable...and that I don't have to spend a fortune keeping it on the road.
  10. #90
    Mt Cotton
    Two words stand out from your comment and I love them "less complexity "
