A few more updates over the last few months.
I now have a 'tune' with EGR and DPF delete, it did not make much more power but it definitely drives a whole lot better. Also fitted an oil catch can at the same time.
I was looking for more torque mainly due to adding a bunch of weight which has me now sitting at 2720kg as a daily driver with all my work gear.
Fuel economy seems to be better already but only been through half a tank and some of that was under load on the dyno. Time will tell.
Engine also got a chemical clean via a fuel tank additive and also two cans of upper engine cleaner, which it needed badly!
Catch can fitted up behind the fuel pump.
Dyno print out
I've also purchased an 'Enthusiast HexV2' VAG-COM dongle/cable from Ross Tech in the US. Just learning my way around the software at the moment but it seems like it has a large amount of uses which suits me to a tee.
First thing was to reset the service interval reminder and next up is the Haldex coupling service.
Another thing I've wanted for a while was a new set of speakers for the front doors, I went with a 'T5 Focal Speaker kit' from Skipton Car Radio in the UK. Awesome service from those guys with shipping from the UK via DHL arriving in less than a week.
Absolute plug and play and easiest car audio install I've ever done.
Kit come with adapter rings to fit an 8in mid bass in each door and a tweeter up in the factory dash position with all mounts and screws provided as well as 8 sheets of sound deadening matting for the inside of the doors.
The difference is absolutely night and day! I love it.
I didn't get any photos of the install as I was limited for time using the shared driveway space on our property.
Link to the kit here VW T5 Focal 20 cm Speaker Kit
