Results 1 to 5 of 5
Thread: small 10 amp red fuse location?
    Nov 2012
    I've just had to strip my van looking for my wife's wedding rings. Front seats, mats and interior panels all out. I found a small red 10 amp fuse at the base of the passenger B' pillar. The fuse is only 10mm wide, any ideas where it's from, would there be a fuse in the pillar? interior lights, seat belt warning etc??
    Thanks BR
    Mt Cotton
    None of the above , what model van is it T5 or T4 T4 has fuses in a compartment under the dash drivers side T5,s have fuse under the Pass seat and then in the centre below the ashtray . My money is on a dropped fuse either from new or when service work was done .There are no fuses at the base of the B pillar , just check all systems in the van to see if something is not working then look for the matching fuse point and check to see if its missing .Good luck .
    Nov 2012
    Thanks Sunny, I'll check everything but all seems to be working fine.
    Mt Cotton
    Did you find the ring after all that ??
    Nov 2012
    Found the Wedding Ring but not the Engagement Ring. The wedding ring was under the passenger seat where the wires come through the mat. BR
