Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Slow going uphill in my 2002 T4 2.5 TDI
    Aug 2011
    brisbane
    Can you somehow hook up a boost gauge, that will at least tell you there is a problem to start with?
    Jul 2005
    With no maf signal(open or short to ground) there will be no boost as a protection feature. I have line tested the harness from the maf to the ecu and it was all good. I starting to think there is a fault in the ecu and that is easy to check by sending it to someone like Injetronics who can test the input/output.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
