Originally Posted by
Silver Caravelle
2. There is tinny rattling gushing (?) sort of faintish noise from either the water pump area or transmission area. It is an internal noise. But could be perhaps just PD injection noise? Or possibly transmission TQ flex plate or water pump? But sort of doubt it is the water pump.
If any body in Melb with a T5 128 kw auto is available, I would be grateful of some time to compare noises!
Scott,
Good on you for persisting, I hope you get there in the end.
If you are getting the "tinny rattling gushing" noise on over-run you can probably eliminate PD injection noise as the cause - until the engine gets close to idle revs the injectors don't inject any fuel at all and so are very quiet (that's why the MFD will display fuel consumption of 0.0 l/100km on the over-run). I can actually tell how steep a hill is by how much noise the injectors make as I go up it (I call it the "warble" of a working 5 cylinder TDI - sad, I know
If you can't locate a 128Kw auto an audio comparison with a manual 128Kw van will probably still be useful, as it may tell you whether the noise you are hearing is coming from the engine or not.
