Results 1 to 3 of 3
Thread: Should I change my Auto transmission fluid?
    Oct 2009
    I've got an 09 VW T5 2.5l that is about to hit 60,000km's. The transmission isn't as smooth as when I first bought it, so I was wondering if I should change my ATF. Should I or shouldn't I?
    According to the sticky: 7.0L or Penrite SIN ATF
    Filled for life (Not available with 4motion)
    Does it really require 7L's? Seems like quite a lot!
    Feb 2008
    Adelaide,Oz
    Did mine around 75K km.Will be doing again at 150K
    You will only drain about 4 litres,doing it yourself.The rest is in the torque converter.
    how to here
    how to change T5 Auto Gearbox Oil - The Brick-yard
    Steve
    04 T5
    Oct 2009
    Thanks for that. exactly what I was looking for!
