Don't buy one with the non-DSG auto.
The DSG in the MY10-onwards T5GP is a good thing. Problems are few and far between.
Hi guys, new member here. With our 4th child on the way we are looking for a new car to replace our excellent Peugeot 407 diesel wagon.
The Multivan seems like a great option in terms of space and practicality but a bit of research uncovers plenty of DSG horror stories which gets me worried. Boris at Volkscare (Boronia, Victoria) says they are great, it comes down to the individual car and its care and service history. I asked him if he thought an early T5 with conventional 6 speed auto would be a better bet but he didn't really say so.
Any thoughts would be welcome. I realize it's the bad stories that get published on the web, and there are a lot of vans out there. Surely some people must get a good run out of them?
Budget up to perhaps $35k but I'd be happy to hear that a well maintained early T5 with 200,000 on the clock would be a good option!
John
Sent from my SM-G900I using Tapatalk
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Had a good run out of my 04 non DSG, tiptronic auto so far. 150K km
BUT, do my own auto servicing. How to change T5 Auto Gearbox Oil - The Brick-yard
These early T5 autos were supposedly sealed for life, and were ok till the internal filter blocks up, your warranty's out, and all hell breaks loose.
If you buy one make sure to service the auto gearbox.
The DSG type may be a better bet, if your budget can stretch
DSG probs were with the Golf/etc i think, which is a different gearbox
Also early T5 diesels have soft cams, and high pressures due to PumpDeuse setup doesn't help. Avoid 04-06ish
Check servicing for relevant 506.01 or 507.00 oil changes.This is important.
Steve
04 T5
I have the first of the T5.2 from 2010. 155k on it and still running a treat, we love our van... it's so big and practical!
Thanks for the feedback guys...
Some of the reviews on the following site are giving me cause for concern...
Volkswagen Multivan Reviews - ProductReview.com.au
just from a quick read, a lot of those reviewers don't even know which gearbox they have.
The DSG was introduced around 2010 with the (oops) 5.2 update, IIRC
Steve
04 T5
I thought the early model DSG were a problem because of the sealed gear boxes. The 5.2 T5 are ok as you can change the oil and filter access. My 7 Speed DSG 2014 T5 4 motion is a dream to drive.
2014 T5 132Kw Twin Turbo, 2016 "D" Suffix EGR Cooler, 4 Motion, 7Spd DSG + Diff Lock, Frontline Camper.
No DSG prior to MY10 T5GP.
The early ones were just a conventional automatic, and were totally serviceable. But still, they're a ticking Time bomb.
'01 Beetle 2.0
I agree with Rebuild the Tiptronic can be a nightmare if NOT serviced , ours shat itself because VW told dealers not to service them and change the internal filter . So ours was left to suck up burnt fluid which in turn wore internal parts adding more debris to the fluid which then blocks the filter . Took me two years of hammering VW about the reason I believed was the cause of ours demise at then only 120000 kays , they eventually made a "Goodwill "payment of 50% towards the repair . I still to this day believe they knew it was a problem because look at two things that happened in 2010 . 1/ DSG came out and was able to be serviced every 60000 km and 2/ then the best one the filter is on the OUTSIDE of the box . All car makers should be held accountable for auto failures as they do not test in the real world like Australia , they can bang on about how they test in the Nevada desert for a few weeks at best . But a few years in our climate brings out the nasty's that then occur , I loved the one a couple of years back when there were issues with DSG,s in Golfs , they issued recalls in some countries but not Australia . When a motoring writer asked the head of VW here in Australia why our cars were not recalled but in Japan they did get a recall the reply was a masterstroke . As the writer described it the VW head honcho shot himself in both feet at the same time with one bullet . His reply ? Well Australia is different from Japan the Japanese they have hot climate conditions with lots of stop start driving . Good one VW last time I looked deserts were pretty thin on the ground in Japan , stop start driving obviously he lives next door to head office here as most of us will spend several hours a day doing the morning crawl to work .
Just make sure it's not one of the ones built by Chrysler. I forget what model.
Newer tiptronics are good if they've been serviced.
Is a tig not big enough?
