Results 1 to 4 of 4
Thread: Shopping Trolly Pickup
    May 2006
    Adelaide South Australia
    Has anyone spotted the Coles supermarket T6 single cab with fairly long factory built shopping trolley tracks. It is fitted with a compressor & air bags to raise it from ground level. It was being raised while I looked on & there was a motor whirring away. It was fitted with Vic. number plates so maybe doing the rounds to see what the stores think. The operator said it was a nice piece of kit, as long as everything continued to work properly. If I see it again I will take a pic.
    Numerous Mk1 Golf diesels
    Bowral, NSW
    Quote Originally Posted by jets View Post
    Has anyone spotted the Coles supermarket T6 single cab with fairly long factory built shopping trolley tracks. It is fitted with hydraulic or elect. lift to raise it from ground level. It was being raised while I looked on & there was a motor whirring away. It was fitted with Vic. number plates so maybe doing the rounds to see what the stores think. The operator said it was a nice piece of kit, as long as everything continued to work properly. If I see it again I will take a pic.
    I think theres more than one - I saw one drive past work in Parramatta just yesterday!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    May 2006
    As promised, here are some pics. & some more info. There are three of these units operating in Adelaide, & each one is given a name. The one I saw is called Kirsty & is shared between St Agnes shopping centre & Tea Tree Plaza. This driver also confirmed that it was developed & built by VW.
    The tray is lowered by releasing air from the airbags at the rear & a couple of ramps are lowered to the ground.
    After loading the trollies, the tailgate is raised operating a switch that starts an electric motor. This drives a compressor filling the airbags & raising the tray.
    Here's the working part in the black box covered in perforated plate.
    The sticker on the rear window says Birwickvolkswagen.
    Dec 2008
    Sydney/Canberra
