Results 1 to 10 of 13
Thread: Service requirements 2015 tdi400 transporter and dsg question
    Dec 2015
    sydney
    Hi there, I can’t find anywhere online the required items that need servicing, like dsg oil, brake fluid etc. Can anyone help me with a link?
    Also ive read there’s dry and wet clutch dsg out there, what is mine or how do I find out? Thanks!
    Dec 2008
    Sydney/Canberra
    Will be a wet clutch DSG.
    Engine oil and filter every 15K/12mths
    Air filter every 45K/3yrs
    Fuel Filter and DSG service every 60K/4yrs
    Brake fluid and cabin filter every 2yrs
    Haldex oil (if 4Motion) every 3yrs
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2015
    sydney
    Cheers, but is there an actual spreadsheet or something with everything like belts and other fluids?
    is the dsg oil different to the gear oil or are they the same?
    Dec 2008
    Sydney/Canberra
    Only DSG oil in the DSG trans.
    Manual gearbox, bevel box and rear diff (if fitted) is 75W-90 full synth. No set service interval for those.
    One thing I forgot was timing belt is due every 105K/7yrs. Recommend doing the V belt and water pump at the same time.
    '01 Beetle 2.0
    Dec 2017
    I've been going off this
    Sent from my SM-G950F using Tapatalk
    Aug 2016
    NSW
    I think that's a bit out dated.
    The toothed belt on a 2.0 TDI is about 210k to 240k by memory.
    Most of the filter stuff would be close though.
    2018 Crafter Runner
    T5.1 6sp manual.
    Dec 2008
    Sydney/Canberra
    No, the timing belt is still 105K/7yrs.
    '01 Beetle 2.0
    Aug 2016
    NSW
    Post 2010......
    YouTube
    2018 Crafter Runner
    T5.1 6sp manual.
    Dec 2008
    Sydney/Canberra
    Not for the Australian market.
    At 210K, you would be close to putting your third water pump in it by then anyway.
    '01 Beetle 2.0
    Aug 2016
    NSW
    Pulled out the water pump on my second belt change (395k......I think) and it looked as good as the new one!
    2018 Crafter Runner
    T5.1 6sp manual.
