Selling T5 BCP 2007 Highline SWB 200
Volkswagen T5 Multivan 2007, 5 cyl. BCP turbo diesel, auto, 300,001 km, colour: gold; 5 leather seats (front buckets (heated), mid row bench seats); Sony head unit, front and rear camera; tyres 60%; rear hoist suitable for wheelchair transport only (not drop-floor), 4 anchor ratchets installed onto VW standard anchor rails, hoist and ratchets certified by Capital Special Vehicles), Sure-Loc L-Track Titan Series tie-downs, wheelchair access platform lift split hoist twin pillar hydraulic; towbar installed with gooseneck. Two keys. Gauges working normally.
Issues: turbo seal leaking oil into intake (have new turbo and gaskets); rear engine mount failed due to turbo oil leak (have new rear engine mount); snapped manifold stud (closest to brake booster, have new studs and nuts); these issues need to be rectified for roadworthy and reliability. Sliding door[s] manual operated. Needs battery.
$4,377 Neg., with new turbo, new rear engine mount, misc. parts; no RWC. Registered until delivered before 27/09/2024.
I don't have capacity to do repairs. Located in Glen Waverley.
Log into Facebook
Other things my wife said not to mention in the ad:
Turbo gasket cause leaking emissions into the cabin, glow plugs not to preheat correctly, engine light activates, loss of acceleration and performance, makes the engine bay insulation soggy.
Sliding doors issues: right partly works but senses resistance along track; left not working (these were supposedly repaired by GW VW and they left all the bolts loose on the left door). If I were to keep this I'd remove the cables to operate manually.
Locks work but passenger front tends to jam but works. Slide door interior lock knobs have become flimsy. Sliding windows leak with the left lock mechanism faulty.
Once started, deriveable when engine reaches temp. I ran it at idle for 3 hours then went to get fuel about a week ago. Battery doesn't hold a charge. Lights and wipers work. No broken lights. Front windscreen washer hose needs replacing. Windscreen (rain sensing) replaced about 5000k ago. Never been in a bingle.
Brake warning light is on but pads are roadworthy. Have spare new front brake rotor.
Offers are around $3000-3200 but it's on Facy so they rarely communicate and never show up.
- You may not post replies
- You may not edit your posts
Forum Rules
