I've heard that you can usually get two replacement driveshafts per gearbox stub shaft. Driving gently from stopped is supposed to help them both last longer.
Good explanation from VWtech for the unusual drive arrangement for the A/C on the R5 (2.5 5 cyl) engine in T5s (and Touaregs), the same drive arrangement is used for the alternator.
IIRC the toothed rubber doover ("Gates coupling") is a service item that is supposed to be replaced regularly (every 80,000 miles or 130,000Km ?)
A/Cs and driveshafts both seem to fail on T5s more often than they should, poor design/quality/engineering IMHO.
