Results 1 to 10 of 13
Thread: Seat belts?
    Now Adelaide!!!
    Seat belts?
    I have just been looking on Ebay.com.au and seen this camper...
    http://cgi.ebay.com.au/ws/eBayISAPI....ayphotohosting
    Can you guys tell me the answer to this question..
    Do you not have to have seat belts in the rear of your vehicles in OZ?
    One of the reasons i ask this is,
    The Variotech seat this van has in it can not be fitted with seat belts.
    And the vehicle used is a transporter/van so did not have the seat belt mounting points fitted at the factory.
    Only the caravelle or the long nose van versions (same front as later caravelle) had them fitted.
    Thanks Rob
    Jul 2009
    Geelong, Victoria
    yes, rear belts should be fitted
    the exception is older cars that were not originally fitted with seat belts - e.g. i have a 1960 Austin Healey Sprite, not originally fitted with seat belts. When i finally finish it, i will not have to put them in for registration.
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Nov 2006
    Newcastle NSW
    I cant see any seat belts in the back either. Could they be lap belts only and are pushed down between the seat in the photos? Maybe contact the seller and ask them.
    If it does not have belts in the back, it probably only has a 2 seating capacity on the compliance plate - it just means you cannot carry passengers.
    Jun 2007
    Melb.
    Unless the owner can provide you with an engineer's certificate for the fitment of the rear bench and it re-registration as a 5 seater then it's not road worthy for carrying passengers in the rear. In some Australian states roadworthy certificates are required every year.
    May 2006
    Adelaide South Australia
    Quote Originally Posted by rob64981 View Post
    My Trakka is fitted with the same seat & has 2 seat belts fitted. I would think the seat in the advert would have belts fitted.
    Numerous Mk1 Golf diesels
    Now Adelaide!!!
    Jets,
    What sort of seat belts does yours have?
    The variotech seat was never tested with seat belts to my knowledge.
    Thats why lots of people have problems here in the UK.
    Rob
    May 2006
    I am away holidaying at the present, wont be home again to look until next Sunday. Seat belts in Aust. must be tagged AS..... [Aust Standard].
    Sep 2008
    Gold Coast
    You'll likely find the vans do have the rear seatbelt mounting points fitted, at least the wall points. They are in evidence in my 2 seat Transporter van and even have the lower mount belt trim covers capping the opening where the inertia reel assembly would be bolted. It makes no sense from a manufacturing standpoint to not include the mount points in common pressings such as wall frame rails; why have 2 (very expensive) dies when one will do? The floor is a different matter as it's a single skin that requires a hole through to the outside and a reinforcement plate as part of the bolt mounting hole.
    Nonetheless, speaking from bitter experience of fitting extra seatbelts in Queensland, it wouldn't matter if all the mounting holes were there already and you bought all factory bits - they'd still want an engineer's report and to rivet a bloody ugly big blue modification plate on your vehicle. One '98 Transporter I looked at while shopping for mine had 3 mod plates - one each for a second row of seats and a rear sideways facing jump seat added at different dates, and another for the LPG conversion.
    May 2006
    From memory my belts are bolted to the seat frame as the seat can be moved along tracks in the floor. One belt is lap sash [one mount on side of van] & the other is lap only, mounted to seat.
    Now Adelaide!!!
    Quote Originally Posted by Deeceer View Post
    There are quite a few differences in the shells that left the factory.
    One of them is the double skin in the rear third of the transporter.
    If the shell was meant to have seat belts then it is double skin.
    If its not meant to have seat belts then its single.
    They all have the locating points at the bottom.
    The transporter that is meant to have seat belts in the middle of the van has captive nuts fixed in place where the top of the seat belt fixes to.
    If its not meant to have seat belts then there is just a hole.
    You can put a captive nut up the inside if the skins and rivet it in place to stop it moving(dropping) if the seat belt was ever removed.
    The bottom still has the locating points and nut always.
    There are quite a few other things that happen at the factory like middle and rear windows...
    The inner and outer skins are welded together if done at the factory.
    Most after sales convertors stick them together some other way.
    Windscreen adhesive is a typical way.
    Rob
