Possibly one of the seatbelt stalks.
On my transporter the seat belt warning light and beeping has become continuous whilst driving.There is nothing on the passenger seat. Have tried by moving the belts etc. Any ideas?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
If I am not mistaken is there is a sensor under each seat which tells the airbag if someone is actually seated not just the belt being plugged in , maybe another option to look at .
Transporters dont have the seat sensor from memory..some passenger cars do...but only on the left front seat...its not required on the drivers seat as the abs sees a rotation speed then it knows theres got to be a driver...the seat sensor is not used used for the airbags. Only used to indicate a passenger sat in that seat...the airbags will deploy if people in the car or not.. seatbelt stalk 90% will be your issue or trapped wire under the seat.......VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
