Results 1 to 7 of 7
Thread: Seat Belt warning alarm.
    Sep 2010
    Gosford NSW
    I dont know about anyone else but i find the seatbelt not on warning noise quite annoying when im not actually needing to be wearing the seat belt.
    Has anyone found a way of turning this off or disconnecting it? (short of putting it in the clip) . I was thinking there might be a way of bridging it out down on the clip/reciever.Has anyone every done this?
    Thanks
    Roger
    Adelaide hills, SA
    Easy done with VCDS.
    Feb 2008
    Adelaide,Oz
    There's a connector under the driver's seat.Disconnect it.
    Steve
    04 T5
    Dec 2008
    Sydney/Canberra
    Or not. You'll have an annoying Airbag Fault ding.
    As Transporter suggested, get a dealership to code it out, or just plug the seatbelt in, then hop in.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2008
    Sunshine Coast
    You can even buy seat belt clips for this purpose !
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Mt Cotton
    Another option I did once on an Astra was with the key in switch it would chime even when you were listening to the radio with a door open . I found the darling little chimer in the centre of the fuse box , I got a 5 ml drill bit and drilled its bloody annoying heart out !!! .Howard PS I am not suggesting this line as there are so many warning chimes that knowing todays technology you would probably cause the van to have a heart attack and stop working .
    Adelaide hills, SA
    I closed this thread, since the topic is now covered in the VCDS resources (section of the vwwatercooled forum). http://www.vwwatercooled.org.au/foru...tml#post705036
    Also, there is post in the "How to do this and that" stickie in our forum, should you later have a need to find that post.
