Results 1 to 3 of 3
Thread: VW T5 R5 TDI AXE Waterpump seals
    Sep 2022
    Eltham Victoria
    Hi all ,
    Have a new water pump to install and just seeing if anyone knows which of the seals goes next to the impeller and which one next to drive cog ? One is a Green o ring the other is a black one . the Green one is a much firmer material the black one similar to normal o ring stiffness.
    Thanks for any help .
    Feb 2008
    Adelaide,Oz
    Geez, been a while since i did mine, can't remember. I just fitted the aftermarket Borg and Beck pump as supplied with orings already fitted.
    Is it a OEM pump?
    Ring em up and ask?
    When you fit it, make sure the oring surfaces are free of rust and debris
    Steve
    04 T5
    Jun 2012
    NSW
    They are different sizes, place in groove that fits. green to gear, black to impeller (if this picture is correct)
    VW T5 R5 TDI AXE Waterpump seals-water-pump-t5-png
