Results 1 to 4 of 4
Thread: T5 Variants Looms
    Jun 2008
    Seaford, victoria
    T5 Variants Looms
    Hey guys, I just wanted to start a thread on the wiring of the T5's. See if we could get some brains together to sort out a few things.
    My main question is, are all the wiring looms for the T5's the same whether the accesories are fitted or not. I got told by a friend that all the wiring is there from factory across all t5 models. So for example if you had a standard t5 van and you wanted to install the vw sat nav from a multivan/caravelle you could just plug it in or if you wanted to install fog lights from a multivan/caravelle you just install the lights and get the correct headlight switch. In a nutshell he said that the wiring is there even if it is not being used. Can anyone confirm or deny this?
    Jan 2007
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    Canberra
    Or even if the wiring is there it might not work correctly eg if you put the Multivan twin reflector headlights in a std van the connector plugs straight in to the new headlight unit, but you only get the inner globes lighting up on high beam, not both inner and outer (low beam) globes as you do on a Multivan.
    Jan 2007
    sydney
    no wiring for fog lights in front bar.Need to pick up supply from head light switch. I have installed Narva 80mm fog lights, work very well.
    1st place Mk3 Standard 08
