Results 1 to 4 of 4
Thread: Running battery cable through firewall help required
    Apr 2013
    canberra
    Hi, adding a dual battery to a 2007 T5,
    Does anybody have a suggestion on where I can run the battery wire from the start battery and through the firewall to under the drivers seat,
    Cheers.
    Adelaide hills, SA
    Remove the black metal plate behind the battery, there is a grommet in the fire wall, that you can run the wire through.
    Apr 2013
    canberra
    Thanks much appreciated,
    Matt
    Adelaide hills, SA
    Here is the picture. I fed the wire through the cavity in the inner guard starting closer to the headlight, rather than drilling through that black plate.
    Running battery cable through firewall help required-t5-second-battery-wire-jpg
