Under the passengers side below the glove box , also check the intakes outside we had a dead bird in ours once phew !!
2015 tdi400. When the aircon isn't on and just straight air is coming out during the first few mins of running there's a noticeable odor coming out.
Has anyone had this? Where are the cabin filters?
Sent from my GT-I9505 using Tapatalk
Open the bonnet look along the plastic part at the bottom of the windscreen lots of slotted holes to allow the air to get through , you may also note that this same area also allows water to drain out of the Blenheim chamber so it is important to remove and clear the leaves and debris in there . On the passengers side there is a square hole with a honeycomb grill over the opening its is on the vertical part of the internal firewall , this is the intake to the inside of the van which then leads to the filter and out the vents inside .
Thanks, turned out there was a dead lizard at the cabin filter!
This forum has been a bag of laughs this week , glad you found the culprit .
A Blenheim chamber would be a bit wobbly at the momemt Still a lots of after shocks there..
Its actually a plenum chamber. Sounds the same with a mouthfull of lollies LOL
Yes you are right bloody Kiwi towns , try saying Whakatane in local lingo .
