Results 1 to 10 of 12
Thread: Rotten smell coming from air vents at startup?
    Dec 2015
    sydney
    2015 tdi400. When the aircon isn't on and just straight air is coming out during the first few mins of running there's a noticeable odor coming out.
    Has anyone had this? Where are the cabin filters?
    Sent from my GT-I9505 using Tapatalk
    Mt Cotton
    Under the passengers side below the glove box , also check the intakes outside we had a dead bird in ours once phew !!
    Dec 2012
    Sutherland Shire, Sydney
    Repco and Autobarn sell an aircon sanitiser that works very well - use it after replacing the cabin filter
    Rotten smell coming from air vents at startup?-auracca-jpg
    Dec 2015
    sydney
    Care to extrapolate? Where are the intake?
    Mt Cotton
    Open the bonnet look along the plastic part at the bottom of the windscreen lots of slotted holes to allow the air to get through , you may also note that this same area also allows water to drain out of the Blenheim chamber so it is important to remove and clear the leaves and debris in there . On the passengers side there is a square hole with a honeycomb grill over the opening its is on the vertical part of the internal firewall , this is the intake to the inside of the van which then leads to the filter and out the vents inside .
    Dec 2015
    sydney
    Thanks, turned out there was a dead lizard at the cabin filter!
    Jul 2016
    Quote Originally Posted by twistit View Post
    Yup, that would do it.
    Mt Cotton
    This forum has been a bag of laughs this week , glad you found the culprit .
    Pacific Paradise QLD
    A Blenheim chamber would be a bit wobbly at the momemt Still a lots of after shocks there..
    Its actually a plenum chamber. Sounds the same with a mouthfull of lollies LOL
    Mt Cotton
    Yes you are right bloody Kiwi towns , try saying Whakatane in local lingo .
