Results 31 to 35 of 35
Thread: Rotor Sizes
  1. #31
    Jun 2012
    NSW
    My 2 cents
    I would replace rotors with that much wear, here's what I used:
    Brakes International | eBay Shops Brake caliper rebuild kits £12.95ea
    these UK guys were most helpful (to me) and shipped parts out extra quick.
    brakesspecialist | eBay Stores
    Australian Disc Brakes T5 With 16" Rims Slotted & Drilled FRONT Disc Rotors $150 pair
    http://stores.ebay.com.au/Vic-Perfor...p2047675.l2563
    2 x DBA2247 DBA OEM Rear Disc Rotors AU $160.00
    performancecarpartsonline | eBay Stores
    Bendix (front) Brake Pad Set DB1947 $97.70 (non dusty)
    Bendix (rear) Brake Pad Set could not find notes on these, but the rears are dusty,
    changed fluid as well,
    Done 3 years ago, no problems since, still look new, and perform great
  2. #32
    Apr 2010
    South Morang, Victoria
    Quote Originally Posted by Umai Naa!! View Post
    Are those prices including GST?
    Yes...!
  3. #33
    Aug 2016
    NSW
    Those were the discs that warped on mine.............but they are probably OK if you aren't carrying heavy loads and driving down Bulli Pass or My Ousley every day.
    2018 Crafter Runner
    T5.1 6sp manual.
  4. #34
    Apr 2010
    Quote Originally Posted by LogicprObe View Post
    The DBA slotted you mentioned in an earlier post?
  5. #35
    Aug 2016
    NSW
    Quote Originally Posted by blaast View Post
    Yes.
    I was using their pads as well.
    They diagnosed it as being caused by a wrongly embedded sensor wire but I think it was to much heavy braking.
    Anyway, that seller replaced them under warranty no problem.
    (well, I actually had ordered the DBA solid discs from them so I could get the warped ones off and paired them with the Italian pads I've used ever since.)
    I took a full refund for the drilled and slotted discs and pads.
    2018 Crafter Runner
    T5.1 6sp manual.
